Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Dynatrace Intelligence for WorkflowsDynatrace Intelligence for Workflows
Add agentic AI, prompts and built-in analysis to your workflows.
App
Free trialDocumentation
Start a workflow from a ready-made agent.Select from a wide range of Dynatrace Intelligence Analyzers to forecast, detect anomalies, and identify behavioral shifts in metric time series.Integrate Dynatrace Intelligence Analyzers directly into your workflows for smarter, automated decisions.
  • Product information
  • Release notes
Overview
Dynatrace Intelligence for Workflows lets an agent do work on your behalf as a step in a Dynatrace workflow. When a problem is detected or at a time you set, the workflow hands a task to an agent, which works with the tools you allow and within the permissions of the operator it runs as, and returns the result to the workflow, where every following step can use it: annotate the Problem, route it to the responsible team, open a ticket, send an email or Slack message, build a report or notebook, or start a remediation behind an approval step. A person stays in the loop and approves where it matters. Built-in analyzers for anomaly detection, time series forecasting, threshold monitoring and custom analysis let the same workflows recognize patterns in large amounts of data and forecast what is coming, which means an agent can start from a computed finding instead of from raw data.
Use cases
  • Run an agent for the autonomous investigation of a detected problem: it runs its own queries and writes the root cause, key findings and recommendations onto the Problem.
  • Diagnose a Kubernetes anomaly with parallel queries and write the cause and a corrected YAML block back as an event on the workload.
  • Attach the cause and a suggested code fix to a mobile crash problem.
  • Create ServiceNow, Jira or Jira Service Management incidents that already name the cause.
  • Summarize open problems, rank them and send the result as a daily report by email or Slack.
  • Forecast capacity demand and scale resources before a critical incident occurs.
  • Detect changes in service behavior and notify teams before an SLA breach.
  • Run custom analyzers on Grail data to surface trends or compliance risks.
Get started
  1. Enable Dynatrace Intelligence for Workflows in your environment. The generative and agentic AI actions and the analyzers then appear under Dynatrace Intelligence in the Workflows Choose action section.
  2. For the generative and agentic AI actions, an environment admin turns on the generative and agentic AI functionality under Settings > Dynatrace Intelligence > Generative and agentic AI, and the relevant user groups need a policy that allows davis-copilot:conversations:execute.
  3. In Workflows, go to Settings > Authorization settings and grant the following primary and secondary permissions:
  • app-engine:functions:run
  • davis:analyzers:read
  • davis:analyzers:execute
  • storage:bizevents:read
  • storage:buckets:read
  • storage:events:read
  • storage:logs:read
  • storage:metrics:read
  • storage:spans:read
  • storage:system:read
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Customer story Mitchells & Butlers
“With Dynatrace’s Davis, it’s like having multiple additional analysts on your team. Since we’ve implemented, we don’t go looking for problems, problems come looking for us.”
Mark Forrester
Digital Readiness Manager
See their story
Mitchells & Butlers logo
Related to Dynatrace Intelligence for Workflows
Workflows logo
Workflows
Full version history
ReleaseDate
1.11.1
Patch Changes
  • 6df1832: Tighten the SRE Agent workflow template's prompt: a single-sentence verdict and a hardened anti-narration instruction, reducing conversational preambles in run-agent output.
  • e73dd6b: - Fixes several dql queries that were using the deprecated affected_entity_ids field.
    • Narrows the trigger on problems to only include those where the affected entity is a Kubernetes resource.
    • Fixes the GitHub issue title prompt being rejected by Davis CoPilot.
    • Cleans up unnecessary conditions (edges) in the workflow.
1.11.0
Minor Changes
  • 75143ed: Adds parsing for dynamic list inputs configured with Jinja expressions before calling the analyzer.
  • 08d09d5: Add a new "Run agent" workflow action that lets users pick a specific AI agent (builtin agents and custom agents) and run it with a prompt and further context. It shares the operator execution logic with the Prompt agentic AI action.
  • 9cb24c5: Update the SRE Agent workflow template to the run-agent action, with a new error path for failed and empty-output agent runs.
Patch Changes
  • aca36e0: The Kubernetes troubleshooting agent workflow now annotates problems using the platform's Comment on problems action instead of a hand-rolled Davis event.
1.8.1
Patch Changes
  • 45e496b: Add scopes for storage:fieldsets:read and storage:files:read.
1.8.0
Minor Changes
  • 868bf8c: Remove auto-migration of deprecated timeframe units in widget configurations.
  • Update dependencies.
1.8.0
Minor Changes
1.7.0
Minor Changes
1.6.0
Minor Changes
  • e2a6660: Introduce Davis rebranding.
Patch Changes
  • f0bc0b5: Update dependencies for vulnerability fix.
1.4.1
Minor Changes
  • 613609d: Update analyzer timestamp validation.
1.3.1
Minor Changes
  • a5b97a8: Support "Simple workflows" for "Analyze with Davis" action.
1.2.0
Minor Changes
  • Support long-running Davis analyzer tasks.
  • Migrate to Workflow Actions v2.
Patch Changes
1.1.7
Patch Changes
  • Update Davis components
1.1.5
Patch Changes
  • Update Davis icon.
1.1.4
Patch Changes
  • Miscellaneous updates.
1.1.3
Patch Changes
  • 3208652: Execution logs.
1.1.2
Patch Changes
  • Miscellaneous updates and stability improvements.
1.1.1
Patch Changes
  • 4c00e30: Request scope for grail entities.
1.1.4
Patch Changes
1.1.3
Patch Changes
1.1.2
Patch Changes
1.1.1
Patch Changes
1.1.1
Patch Changes
1.0.2
Patch Changes
1.0.1
Patch Changes
  • 858600a: Update documentation.
1.0.0
Major Changes
  • Initial release.
Dynatrace Hub
All (947)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Dynatrace Assist logo
Dynatrace Assist
Smartscape logo
Smartscape
Compliance Assistant logo
Experience Vitals logo
Experience Vitals
Optimize UX with core vitals, frontend error tracking, and end-to-end visibility.
Error Inspector logo
Error Inspector
Users & Sessions logo
Users & Sessions
Replay how users experience your frontend. Analyze behavior and outcomes.
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
