Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
InvestigationsInvestigations
Investigations
Investigations
App
Try in PlaygroundDocumentation
You can see your whole investigation flow as you go along with the ability to always jump back to the previous step of the investigation.Detailed view of the record will show all record fields at once with the possibility to drill down to the details of the field.You can use the data in results with the character precision. Creating new evidence of DQL filters can be done by selecting portion of the field.Evidence and filter manipulations can be done with multiple values: just select the range of IP-s and create a DQL filter based on the values!Investigations enables you to view your data in wrapped and multi-line modes. With Inspector view you can also visualize the non-printable characters.
  • Product information
  • Release notes
Overview
Dynatrace Investigations is one of the pre-installed apps shipped with Dynatrace. It's designed for evidence-driven security use cases based on the logs, metrics, and traces ingested into Grail.
  • Keep your whole investigation flow in context
  • Analyze large DQL results in their original form at a detailed level
  • Perform complex investigations on data stored in Dynatrace Grail®
  • Build DQL queries quickly and efficiently based on your findings
  • Save and use the found evidence to build your DQL queries and find answers to your questions
  • Navigate with ease to any point in your investigation history and review queries and results
  • Fetch detailed results in the original format to quickly understand the information
  • Analyze the observability metrics connected to your log sources
Use cases
  • Threat hunting and hunting for the unknown
  • Forensic analysis, where keeping track of the investigation is a must
  • Incident root cause analysis, where evidence-driven queries bring clarity to the incidents
  • Create faster filters for DQL queries to speed up any investigation
  • Investigate API call throttling using DQL and Investigations
  • Debug AWS Integration issues
Learn how to perform threat hunting and forensics
Are you looking for additional use cases and functionality? Let us know in the Dynatrace Community Forum!
Get started
Investigations comes preinstalled on Dynatrace SaaS environments. Launch the app and Create your first investigation scenario.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Related to Investigations
Grail logo
Grail
Dynatrace's data lakehouse providing unified storage for any type of data.
Full version history
ReleaseDate
1.348.0
With this release you can now
  • View your Investigations in a table form to get a more condensed view of your working items
  • Highlight the values that you filtered with your DQL query directly in the results table
  • Copy data from your results table using keyboard shortcuts
  • Toggle the query node labels to find your queries faster
  • Search quoted keywords for precise matches in your results table
  • See all available shortcuts that speed up your work with Investigations
1.343.1
  • develop your query faster with the query editor context menu which provides quick access to editors functions like duplicating query lines
  • create Grail Lookup tables in a faster and more convenient way from the whole result set
1.339.0
With this release, minor fixes and improvements were added to improve your user experience.
1.336.0
With this release you can now:
  • See the references to Dynatrace entities (e.g. Security Events in Threats & Exploits), where the Investigation was started from, keeping track of all the connected entities relevant for your investigation
  • Bookmark your most relevant investigations for faster access
  • Selecting all the descending nodes from in a query tree to speed up query management in Investigations
1.334.1
1.332.1
1.330.0
Security Investigator is now called Investigations!
Additionally you can now:
  • easily choose to show and hide columns in the results table
  • access distributed traces from your results in a faster way from the right-click menu
  • filter record details by their column name or a value in the Record Details pane
1.329.2
With this version of Security Investigator you can now
  • Create DQL queries, add filters to your query and highlight logs in results table from Performance Metrics chart
  • Create lookup tables from query results or from files from your disk
  • Create custom results pivoting dimensions
  • Beautify your DQL queries in Query Editor using a shortcut Mod+L
1.324.0
  • Create reference time and query filters directly from Performance Metrics charts
  • Upload files from your computer and store them as Lookup tables in Grail
  • Create lookup tables from your query results
1.323.0
Minor Changes
  • to performance metrics
  • to results table
1.320.1
Minor Changes
1.319
With this release You can now
  • View performance metrics of the system from query results
  • Set reference time from record details
  • Enrich IP addresses in your DQL query results
1.317.2
  • Enrich IP addresses for additional context from external sources
  • Download cases as templates and vice versa
  • Get more data with fetching data from Grail up to 300mb at once
1.316.1
  • Quickly shift your investigations based on metadata fields using Query Pivoting. Read more from Dynatrace documentation
  • Copy your results in CSV format to operationalize your query results
  • Access filtering and copying functions from the Record Details view
  • Fetch data from Grail up to 300MB at once
1.313.1
  • Share cases with all environment users in read-only mode at once
  • Upload cases as templates and vice versa
  • Select all values in a column at once from the column header menu
  • Search results table by a keyword and jump to the next occurrence of your search keywords
  • See the in-place filters count above the results table
  • Define query editor settings - toggle between condensed and normal code view and enable/disable line wrap
1.312.0
With this version you can now:
  • use chart visualization automatically when fetching timeseries data
  • use reference time as additional context when conducting investigations.
  • enable the line wrap option from settings for DQL query window
1.310
  • Save multi-line evidence to evidence list
  • Use automated charts for data visualization
  • Access security events in Grail
1.308.0
With improved case management features, you can now
  • duplicate existing cases to create snapshots or continue cases that are shared with you
  • download and upload the cases to move them between environments
  • create use case templates as boilerplates for your investigations
To streamline investigations, you can work with your findings more efficiently by clicking on evidence to copy it directly from your Evidence list. You can use the copied evidence in DQL queries, or case reports directly and fast.
To speed up investigations and grasp results faster, you can now visualise your results as charts
Minor changes:
You can now
  • access query tree color labels and their titles from the query tree legend
  • view complex data elements (like arrays and records) in a multiline mode in the response table
  • share your cases from the main page without opening the case
  • share templates with everyone on your environment with one click
  • filter your cases and templates on the main page by their type: either view All the cases accessible by you, see only My cases or only cases that have been Shared with you.
1.305.0
With this version of Security Investigator it is now possible to:
  • Create custom timeframe by clicking on analysis timeframe in result statistics.
  • Add time range filters for timestamp data type.
1.304.3
  • Download selected nodes as a Notebooks document
  • Upload evidence to an evidence list from text file
1.302.1
Patch Changes
  • Minor bug fixes.
1.302
  • execute a query without creating a new node
  • add IP addresses from a string-type fields to IP evidence lists
  • create new cases from every page of the Security Investigator
  • access Distributed Traces when analyzing your logs by right-clicking on the record in the results table
  • see Duration datatype in the results table in a human-readable format
1.298.8
Patch Changes
  • Fixed bugs related to sharing in safari.
Major Changes
  • Introducing Case Sharing: It is now possible to share your investigations with peers and stakeholders!
    • You can share your cases with either a link or share cases to a person or a group.
    • Cases can be shared in either a read-only mode or with edit privileges.
    • Read more at https://www.dynatrace.com/news/blog/collaborate-with-peers-in-hunting-security-threats/ .
1.295
  • A search field has been added to highlight keywords in the result table.
  • User can set record limits for DQL queries in the App settings
  • Added color legend with customizable color labels in query tree.
1.291
You can now:
  • View the query tree legend to see the explanations of different query node statuses.
  • Rename your cases on the main page in the Cards' menu.
  • Open the Security Investigator from other Dynatrace applications.
1.290.0
Minor Changes
  • Updated result statistics and notifications.
  • Added a new result status indicator to the query tree.
  • Added a context menu to the field details window.
1.289.0
Minor Changes
  • 138f865: Added filtering to the context menu in the record details window.
  • 29ce2db: Added an 'Add field' command for nested objects in the record details window.
Patch Changes
  • 5f84f0a: Added the selected record number to the record details window.
  • 9fa665a: Updated the result table context menu.
  • f05b039: Added a 'Copy field' option to the context menu in the results table.
1.288.0
Patch Changes
  • 4574b72: Close inspect and complex view if DPL Architect is opened. Remove back button if inspect view is opened directly from result table.
  • f2c946e: Added possibility to cancel queries in multiple nodes that are running at the same time
  • 50573cb: Close DPL Architect if case is switched. Close toasts after 5 seconds.
  • 662d89d: Modify query tree deletion portion. Strip trailing newlines and scroll editor to bottom when DQL is added to query.
  • 542c37e: Cosmetic improvements
  • cda16d3: Update adding new evidence collections
  • 834049a: Add help menu
  • eb8a6cd: Add view-query intent
1.0.0
Patch Changes
  • c6d0b00: Update record count on poll response
  • 51b21a8: Remove milliseconds in timeframe selector
  • 241ef0e: Add multiline and line wrap support
  • c92a971: Different nodes can be polled separately and result is updated only for selected node
  • b6d7178: Add case heading menu
  • a971214: Add filter out option
  • 62b4e45: Update result statistics timeframes
  • ce7d7fa: UI improvements
  • 8305454: Update complex view and timeframes
  • 787ada3: Fix submit forms with enter
  • f7c31f4: Add header filter and timeframe rename
  • 3cd4e5e: Multiple samples now can be passed to DPL Architect when clicking "Extract fields"
  • a35f624: Add metrics, bizevents and spans scopes
  • 11d1490: Add filter and delete for selection in collection details
  • 59e45c0: Analytics walk-through e2e tests
  • c1a9045: Ask the user if he wants to cancel polling queries
  • 58e79cd: Fix filterOut statements
  • 7f3d38b: Add new collection creation in context menu
  • 1fb2569: Update zooming in query tree
  • f3249db: Rework details panel
  • 6923e54: Add JSON formatting into detailed content viewer
  • 59b0f6b: Add evidences from collections list menu
Dynatrace Hub
All (947)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Dynatrace Assist logo
Dynatrace Assist
Smartscape logo
Smartscape
Compliance Assistant logo
Experience Vitals logo
Experience Vitals
Optimize UX with core vitals, frontend error tracking, and end-to-end visibility.
Error Inspector logo
Error Inspector
Users & Sessions logo
Users & Sessions
Replay how users experience your frontend. Analyze behavior and outcomes.
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
