Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Dynatrace Live Debugger on WindsurfDynatrace Live Debugger on Windsurf
Technology
Free trialDocumentation
Real-time code-level snapshot in Windsurf IDE
  • Product information
Overview
Instantly access live, code-level data to troubleshoot and understand complex, cloud-native applications, reduce troubleshooting time and enhance productivity and developers satisfaction. Main capabilities include:
  • You can access the necessary and relevant data without adding additional code, waiting for redeployment, or attempting to reproduce issues locally.
  • Using non-breaking breakpoints, you can instantly see the complete state of your app, including stack trace, variable values, and more, all without stopping or breaking your running code.
  • Having the Dynatrace data presented directly in your IDE, helps you maintain the flow without losing time or losing context jumping between tools and screens.
  • The Dynatrace live snapshot contains variables values, stack trace, process and tracing information.
  • The code you want to debug is already present and ready in the IDE, hence source fetching is not needed (as in the Live Debugging web-app).
  • Enhance your troubleshooting experience by integrating MCP server and asking Dynatrace to help with real-time data and insights in natural language via MCP client and AI assistance. read more about Dynatrace MCP and Local MCP.
Use cases
*Capture real-time debug data - Instantly understand the state of your application with instant snapshot output of data and context
*Troubleshoot faster - Instantly debug complex flows and apps including third party and open-source components without stopping your app
*Dev-friendly debugging experience - On-demand and intuitive access to code-level data from any environment directly to your Windsurf IDE
*Test and optimize your code faster - Instantly understand if specific line of code was reached at all with exploratory analytics
Get started
Requirements:
  • A Dynatrace account with DPS licensing
  • Code Monitoring rate card enabled
  • VSX version 1.85.0
  • For all permissions pls refer to Docs here
You can install the extension from the VSX Marketplace or directly from the extensions tab inside your Windsurf IDE.
  • Install the extension.
  • Open the Dynatrace Snapshots panel. The panel is located at the bottom of the IDE.
  • Log in to your Dynatrace account from the Dynatrace Snapshots panel.
  • Select the environment you’d like to debug by clicking on the cloud icon in the Dynatrace Snapshots panel header. The environment picker will open above, displaying all Dynatrace environments where you have Live Debugging permissions. Select an environment from the list.
  • Configure your debug session by clicking on the pencil icon in the Dynatrace Snapshots panel header. Only instances with Live Debugging enabled will appear. Select filters for the instances you’d like to debug and click “Set”.
  • Add a Live Debugging breakpoint. Right click next to a line number to add a Live Debugging breakpoint. The breakpoint will be applied to instances matching the filters you configured in step 5, within the environment selected in step 4.
  • View data. When your breakpoints are triggered, data will stream into the Dynatrace Snapshots panel. Click on a snapshot to see local variables, stack trace, process information, and tracing data.
Details
Works with VSX version 1.85.0 or later. Dynatrace active support is currently provided for VSCode and JetBrains IDEs only.
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Copy to clipboard
Dynatrace Hub
All (947)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Dynatrace Assist logo
Dynatrace Assist
Smartscape logo
Smartscape
Compliance Assistant logo
Experience Vitals logo
Experience Vitals
Optimize UX with core vitals, frontend error tracking, and end-to-end visibility.
Error Inspector logo
Error Inspector
Users & Sessions logo
Users & Sessions
Replay how users experience your frontend. Analyze behavior and outcomes.
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
