Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Threats & ExploitsThreats & Exploits
Threats & Exploits
Threats & Exploits
App
Free trialDocumentation
  • Product information
  • Release notes
Overview
Threats & Exploits streamlines the triage of security findings, offering an up-to-date view of the application security threat landscape enhanced by Dynatrace deep observability. It helps you immediately detect zero-day vulnerabilities and take defensive measures to protect against exploitation.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Full version history
ReleaseDate
Patch Changes
  • Fix an issue in RVA settings showing as misconfigured wrongly
Minor Changes
  • When opening an investigation from a finding, the investigation now receives the name of each query alongside its content, giving the investigation tool richer context to work with.
Minor Changes
  • You can now add filters directly from entity cards in the finding detail view, including the affected entity card, entry point card, and request card, making it easier to narrow findings to a specific entity without leaving the detail panel.
  • The quick-action menu is now visible on hover across more plain-text fields in the finding detail view, including request, vulnerability, and cloud context sections.
  • A Share feedback option is now available in the Help menu, letting you send feedback about the Threats & Exploits app from anywhere in the application.
Patch Changes
  • Fixed an issue where the related findings card would silently truncate results; the card now shows a warning when the number of related findings exceeds the display limit.
  • Fixed an issue where the findings chart used severity-level colors when aggregating by a field other than severity, causing misleading color coding for non-severity groupings.
  • Fixed an issue where applying a filter from an entity context menu in the finding detail view did not update the main filter bar as expected.
Patch Changes
  • Fixed display and filtering issues in the MITRE ATT&CK card that occurred when a finding had no matching tactics or sub-techniques — sections now render cleanly and filter calls no longer run unnecessarily.
  • Fixed an issue where searching findings by free text from the filter bar did not apply to the results, returning an unfiltered list instead.
  • Fixed the close button being misaligned in the finding detail panel when the finding has no title.
  • Findings without a title now show an italic placeholder label in the detail panel header and in the related findings list, instead of appearing blank.
  • Fixed an issue where findings with an empty affected entity name showed a blank entity label in the detail panel; the entity ID is now used as a fallback. Findings missing a creation time also now load correctly instead of failing to display.
Minor Changes
  • Added a MITRE ATT&CK card to the finding detail page, displaying the associated tactics and techniques with a detail modal for in-depth information.
Patch Changes
  • Fixed the Smartscape filter in the entity context menu to only trigger lookups for valid Smartscape entity types, preventing incorrect queries.
  • Fixed the source card context menu to correctly handle non-ID entity references, preventing invalid queries from being sent.
Minor Changes
  • Finding detail pages now display a cloud context card with AWS, Azure, or GCP resource metadata when those fields are present on a finding
  • Investigation guidance card now executes DQL queries inline in a modal instead of opening the Investigator app
  • Source card now uses the standard observability key-value list component for improved rendering consistency
  • Source card correctly remeasures virtualized row heights when expanding or collapsing long values, preventing collapsed rows from retaining their expanded height
  • Findings table now has a general search option
Minor changes
  • Add remediation action card in case finding.remediation is part of the finding
  • Improved empty state handling for Actor, Affected object and Related entities cards
  • Add evidence query to list of Investigation guidance queries if available
  • Added description card and useing finding.url for backlinks
Minor Changes
  • Replaced Vulnerability and Detection finding buttons with the new Security Chip component.
Patch Changes
  • Removed legacy idClassic and entityId fields.
Minor Changes
  • Removed Monitored Entities path from Related Entities Card and replaced it with full Smartscape compatibility
  • Removed "Process group", "Process" and "Affected entity" filters
Patch Changes
  • Change styling of surface elements in Detection sources to improve color contrast
  • Remove Monitored Entity fallback from the Affected Object card
  • Reduce required scopes for the app
1.22.1
Minor Changes
  • Add related smartscape node ID filter + updated view-findings-for-entity intent
Minor Changes
  • Batch in-table settings changes
1.20.0
Minor Changes
  • Showing aggregation chips in main findings table when grouping is active
  • Add "Add as filter" to findings chart legend actions
1.19.0
Minor Changes
  • Add view-findings-for-entity intent to navigate T&E with entity-scope filter
1.18.0
Minor Changes
  • Add support for custom enrichment in integrations list.
  • Added new intent to open integration screen
Patch Changes
  • Improve security-intelligence AI context truncation
1.17.0
Minor Changes
  • Affected object lookup extended to also consider object.id to find Smartscape node
Fixes and maintenance
  • Use different logic to reduce app function response size
1.16.2
  • Use toSmartscapeId to convert string ids for comparisons
1.16.1
  • Renamed "Open case" to "Open investigation" to align naming
  • Fixed issues in smartscapeNode query
1.16.0
Feature updates
  • All security.events queries are now free of charge.
  • Disabled entity intents for smartscape_source.id
  • Findings with actor.ips not conforming to the semantic dictionary are filtered out
Feature updates
  • Finding Details now provides "Open case" intent in Investigation guidance section for easier analysis
  • Findings Details now shows Details tab by default for all findings, selected tab is persisted for the session
Feature updates
  • Findings table: you can now group rows to organize related findings.
  • Finding details: the details view now shows insights into related findings.
  • Fix: investigation queries are again offered when a finding contains only an actor IP or a trace ID.
  • Updated Kubernetes filters and added column grouping for Kubernetes and Hyperscaler columns
  • Fixed issues in investigation guidance queries
  • Removed support for events using detection.type, detection.action and dt.security.rap.action fields
Feature updates
  • Remove ownership component from Affected Object card
  • Added filters to better filter for Hyperscaler and Kubernetes-specific fields
  • Added columns to the findings table to show Hyperscaler and Kubernetes-specific data.
  • Added view topology button for Dynatrace monitored entities
  • Improved clarity of settings permission tooltip
  • Fixed alignment issues in the form fields for allowlist rules in RAP settings
  • Fix duplicated input field in Allowlist form
Feature updates
  • Affected entity, related entity, and entities in the Source tab are linked to their respective apps if supported
  • Offer "Open in Investigations", "Open in Notebooks", and "Open with" from the table and finding details
  • Investigation guidance is collapsible and shows the number of queries
  • Increased the number of investigation guidance queries
  • Renamed "Properties" button to "Show properties".
  • Add support for downloading table as CSV for fields: ID, Affected entity, Affected Smartscape node, and Vulnerability
  • storage:smartscape:read permission is now mandatory to avoid issues loading Smartscape related data in the findings table
Feature updates
  • Added "Investigation Guidance" section to replace the "Logs" tab
  • Segment selector is visible again
Feature updates
  • Added intent links to “Affected entity” and “Affected Smartscape node” columns
  • Moved segments and timeframe selector to the filter bar line
  • Added affected object and related entity context to conversation starter
  • Added Properties details to “Affected object” and “Related entities” cards
  • Added context value to the Prevalence chart sparkline
Feature updates
  • Updated "Affected object" card to provide more insights into the monitored entity
  • Introducing "Related entities" card to give insights into topology
  • Introducing more context with number of vulnerabilities, number of detection findings and number of problems per entity.
  • Added "Affected entity ID" filter and column
  • Added "Affected smartscape node" filter and column
  • Added "Affected smartscape node ID" filter and column
  • Adding new intent for severity and affected entity or affected smartscape node
Feature updates
  • Introduced entity type-specific intents to the affected object card and source tab
  • Enrichment: Send NO_READ cache parameters on refresh
  • Fixed wrong default value for RAP GO settings
  • Fixed deployment issue
Feature updates
  • Added IP enrichment feature for actor IP information. For full functionality, the following user permissions are needed:
    • security-intelligence:enrichments:run
    • document:documents:read
    • app-settings:objects:read
    • app-engine:apps:run
  • "Explain with AI" now also gets IP enrichment information to better provide guidance.
  • Fixed issues with enriching EC2 instances for GuardDuty integration.
Feature updates
  • Added 3rd-gen native settings for Runtime Application Protection.
  • Added "Explain with AI" feature to help understand individual findings.
Feature updates
  • General: Switching app to new Security Events table. Changed mandatory permissions:
  • Removed: storage:events:read, Added: storage:security.events:read, Updated: context of storage:buckets:read
  • Detection Sources: All currently available "Security events ingest" options are listed.
  • Findings table: Removed icons for provider, product and vendor.
  • Finding details: Introducing the "Actor" card for finding details.
  • Source tab: Improved rendering of empty arrays, null and undefined
  • Findings table: Switched to finding.type, added backwards compability with detection.type field
  • Findings table: Adjusted "Open with" functionality to improve consistency between apps.
  • Finding details: Improved error messages for 4xx when loading details of a finding.
  • General: Updated app logo
  • App intents now support passing segments and, for the view-detection-finding intent, vulnerability.display_id
  • Segments filter was not triggering a reload of the table.
Feature updates
  • Finding table supports server-side sorting for up to 10.000 findings.
  • Added 'View trace' button to 'Attack vector' card.
  • Search functionality added to Source tab.
  • Improved string array visualization in Source tab.
  • Fixed a permissions issue that prevented users with conditioned permissions to use the app.
  • Changed default sorting to use finding.time.created instead of timestamp
Feature updates
Added "What's new" to the help menu
The “What’s new” section provides insights into the features and fixes provided in the individual releases.
Upgrade dependencies for new functionality and performance improvements
Using the latest Strato library version brings more functionality to the app and improved the apps performance
Improved query performance for detail view
Streamlined queries to fetch only what is needed and when it is needed, improved the loading time of the detail view. Especially when reopening findings.
Improved translation of the app
Table and filters are now translatable.
  • Make table more condensed by adjusted chips.
  • Fixed an issue where info icon above table could not be clicked
  • Fixed an issue where events containing an array of actor.ips containing null not being displayed correctly
  • Deduplicate Entry Point user-controlled input
1.0.1
Major Changes
  • Initial release
Dynatrace Hub
All (947)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Dynatrace Assist logo
Dynatrace Assist
Smartscape logo
Smartscape
Compliance Assistant logo
Experience Vitals logo
Experience Vitals
Optimize UX with core vitals, frontend error tracking, and end-to-end visibility.
Error Inspector logo
Error Inspector
Users & Sessions logo
Users & Sessions
Replay how users experience your frontend. Analyze behavior and outcomes.
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
