Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
SlackSlack
Slack
Slack
App
Free trialDocumentation
Trigger Slack alerts from workflows with full problem context.Configure Slack alerts directly inside the Workflows app.
  • Product information
  • Release notes
Overview
Slack enables you to model communication flows within Dynatrace through actions like these:
Define various notification triggers
  • Use the power of DQL and leverage events to react to any problem, security incident, or attack within workflows.
  • Use Business events as a trigger to react on extended events like a failed release validation, certain log messages, or external system events.
  • Define a scheduler and be informed at specific time intervals.
Flexible content composing
  • Enrich message information with tags, hierarchy details, or any arbitrary entity information.
  • Leverage the expression builder for simple message composition.
  • Reuse workflow step results, such as creating a Jira ticket and posting the ticket number to a specific group channel.
  • Use Slack blocks to format your message.
  • Send a test message to ensure that a connection is configured properly.
Closed Loop Communication
  • Use ownership information to address the correct user groups and reduce repetitive configurations.
  • Update messages within a thread to inform users about changes to a problem state or the progress of a remediation.
Use cases
  • Send Slack notifications when a problem, security incident, or attack occurs.
  • Add reports, logs, and other files for improved insights.
  • Post updates about a problem status or remediation in progress to a Slack thread, giving visualization of the automation lifecycle.
  • Mark a Slack thread as done and add reactions when a problem is closed.
Get started
Install Slack. Then follow the instructions detailed in Dynatrace Documentation.
Before you start, make sure that Slack is installed, outbound connections are configured, and the connection to Slack is authorized.
We suggest that you follow the tutorial in Workflow Automation Creator for more details.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Full version history
ReleaseDate
  • Various improvements and dependency updates.
  • New Request Approval Action – Send approval requests to Slack channels directly from workflows. Supports both internal and external approval modes.
  • New Message Format Switch – Compose messages in Dynatrace Markdown or native Slack format using a new format switch and Markdown editor. Newly created Send Message actions now default to Dynatrace Markdown; existing actions are unchanged.
  • Updated Problem Notification Template – Improved the problem notification workflow template.
  • Link Security for Send Message – Links sent via the Send Message action are now sanitized to protect against phishing.
  • Removed Send Test Message Button – The send test message button has been removed from the Send Message action.
  • Improved Slack Channel Fetching – Improved reliability when fetching Slack channels.
  • Additional Logging for Upload Failures – Added logs to help troubleshoot external upload failures.
  • New Workflow templates – Added ready-to-use Workflow templates, making it faster to set up common Slack notifications and messaging workflows.
  • Improved Error Message for Attachments – Enhanced the clarity of the error shown when a channel name is used instead of a channel ID while sending a message with an attachment.
  • Removed Legacy File Upload Support – The send‑message action no longer supports the deprecated legacy file upload method, which has been officially removed from the Slack API. To continue using file uploads, ensure that the required scope files:read is granted. See the official documentation for details.
  • Thread Reply Enhancement for Intent – A direct link to a message can now be used inside the send-message intent when replying to a thread, making it easier to target and maintain context.
  • Removed Send-Test-Message Button – The send-test-message button is now hidden when sending messages via intent, streamlining the interface.
  • Fixed Connector Management Titles – Resolved an issue where the title was incorrect when no entries were present in the connectors management view.
  • Intent Schema Update Compatibility – Updated the app to support changes introduced in intent schema v0.8.0:
    • Added support for new fields: instantMessage and description
    • Removed deprecated fields: message, target and type
  • Bugfix for Action Widget - Fixed an issue that could cause the action widget to crash when provided with an invalid connection ID.
  • Minor improvements - This release includes a fix for a documentation link.
  • Bugfix for Connection Settings Form - Resolved an issue where the connection settings form remained open after editing a connection.
  • Improved Connection Management - When creating or editing a connection from within an intent, the form now opens in a new tab, offering better usability.
  • New Intents - Reworked the send-message intent to enable forwarding of problems to Slack.
  • Access Control for Connectors Management - Added fine-grained access control for connections, enabling only specific users to have access to connection settings.
  • Improved Attachments Handling - If an attachment is added to message, but the content of it is not set, an error will now be thrown.
  • Attachments in Intents - Attachments can now be sent with intents.
  • Grouped input fields - Improved the user experience by grouping related input fields, making navigation and usage easier.
  • Improved Threaded Messaging Feature - Added the ability to specify which thread a message should be attached to, enhancing message organization and context.
  • Bugfix - Fixed an issue where the attachment title input field would close when clicking a button that is part of the same field.
  • Expression in Connection Selection - An expression can now be used when selecting the connection, providing greater flexibility and customization.
  • Enhanced Error Details - Added error details to Slack API error messages for improved troubleshooting.
  • Send Message Action - Increased the fetching duration for Slack channels to up to 120 seconds, allowing for more robust data retrieval.
  • Connection Management - All connections of the App can now be managed via the newly released Settings App. To manage your connections got to Settings > Connections > Slack.
  • New Connectors Management - Introduce a new, streamlined connection management experience with a modernized interface. This update makes adding and editing connections directly within workflows easier and provides connection control and convenience in one place.
  • App renamed to "Slack" - Streamlined the app name by removing the suffix “for Workflows”.
  • Bugfix: Fixed an issue with dropdowns breaking in Chrome 129
  • Send message action: The intent is now an add-on intent, meaning that it will show up in an in-app modal instead of a different window.
  • Send message action: Visual improvements
  • Bugfix: Fixed an issue in the message field where the cursor occasionally jumped to the beginning of the editor.
  • Breaking change: Changed Connection list to an unordered list.
  • Updated the App icon.
  • Update for uploading files - The file upload feature has been updated to align with Slack's newest functionality improvements. Users might now see a log message guiding them to update the necessary permissions for a seamless experience.
  • New file type for attachments - When adding attachments, the new file type CSV is now available.
  • Maintenance release
  • General App and performance improvements
  • Performance optimizations for threading messages
1.2.5
Patch Changes
  • Fix inconsistency in the select channel component
1.2.4
Patch Changes
  • Removal of settings:objects:read permission since it is not needed anymore
1.2.3
Patch Changes
  • Improve UI of the Slack for Workflows app
1.2.2
Patch Changes
  • Improve error message when unable to fetch channels from Slack
  • Send message action now accepts JavaScript objects as message
1.2.1
Patch Changes
  • Improve input validation error message
1.2.0
Minor Changes
  • Allow "blocks" formatting to be used in messages
Patch Changes
  • Display error details when testing the connection failed
1.2.4
Patch Changes
1.2.3
Patch Changes
1.2.2
Patch Changes
1.2.1
Patch Changes
1.2.0
Minor Changes
Patch Changes
1.2.3
Patch Changes
1.2.2
Patch Changes
1.2.1
Patch Changes
1.2.0
Minor Changes
Patch Changes
1.2.1
Patch Changes
  • 551520d: Improve input validation error message
1.2.0
Minor Changes
Patch Changes
1.0.0
Major Changes
  • Release 1.0
0.4.12
Patch Changes
  • 1095656: Reduce bundle size
0.4.11
Patch Changes
  • b918ece: Required maintenance update
0.4.10
Patch Changes
  • c4573b1: Link to Workflows App
0.4.9
Patch Changes
  • 3343d0a: Minor improvements
0.4.8
Patch Changes
  • d5743dc: Improve User Experience
  • 297b633: Fix Slack channel selector to display the correct channel when editing a workflow
  • b039fdd: Fix channel selector not cleared correctly when changing Slack Connection
0.4.7
Patch Changes
  • 716d9b1: Fix channel selector clearing when invalid connection was selection
  • cce38a4: Document API function and action contracts
  • d38c867: Added a link for Slack Formatting
  • 51f347c: Allow UUIDs and numbers as WorkflowID and ExecutionID
  • 76f4b87: Fix bug that causes the action to timeout if app-state:delete permission is not granted
0.4.6
Patch Changes
  • 8a955db: Fetch only relevant data in ConnectionPicker
  • afea3a1: Added changeset for release notes
  • 8a955db: Fixed: Auto-join slack channels when using reactions on a message
0.4.5
Major Changes
  • Added "Slack: Send message" action
  • Send Slack Messages to a channel or within a thread
  • Upload a file to a channel
  • Ability to react on a message with three default reactions: Thumbs up, eyes (looking) and check mark
0.4.10
Patch Changes
0.4.9
Patch Changes
0.4.8
Patch Changes
0.4.7
Patch Changes
0.4.6
Patch Changes
0.4.5
Major Changes
No release notes
Dynatrace Hub
All (947)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Dynatrace Assist logo
Dynatrace Assist
Smartscape logo
Smartscape
Compliance Assistant logo
Experience Vitals logo
Experience Vitals
Optimize UX with core vitals, frontend error tracking, and end-to-end visibility.
Error Inspector logo
Error Inspector
Users & Sessions logo
Users & Sessions
Replay how users experience your frontend. Analyze behavior and outcomes.
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
