Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Red Hat AnsibleRed Hat Ansible
Red Hat Ansible
Red Hat Ansible
Automate remediation using AI-powered insights with Red Hat Ansible.
App
Free trialDocumentation
Launch a job template in Red Hat Ansible Automation Controller, list job status or retry a job.Integration of Dynatrace workflows with Red Hat Event-Driven Ansible to remediate detected problems or to mitigate security vulnerabilities
  • Product information
  • Release notes
Overview
Connect Dynatrace observability powered by AI with the Red Hat Ansible Automation Platform (or AWX) to turn detected problems into automated action. You accelerate incident response, close the loop on remediation, and cut manual operational work.
This is intended for users who:
  • Use Red Hat Ansible Automation Platform, AWX, or Event-Driven Ansible.
  • Want to automate remediation triggered by Dynatrace problems and events.
Use cases
  • Trigger Ansible playbooks from Dynatrace problems to accelerate resolution and reduce downtime.
  • Automate corrective actions with root-cause analysis powered by AI for faster recovery.
  • Combine observability, automation, and business context to improve IT operations efficiency.
  • Eliminate manual tasks with scalable automation workflows that lower operational costs.
Get started
Install Red Hat Ansible, configure outbound connections, and authorize the connection to the Automation Controller. If your Automation Platform sits behind a firewall, use EdgeConnect to tunnel traffic securely. Follow the steps in Dynatrace Documentation
Details
Integrates with Red Hat Ansible Automation Controller, AWX, and Event-Driven Ansible. Trigger remediation from Dynatrace problems, security incidents, Business Events, or a scheduler using DQL; hand over extra vars to fine-tune playbook execution; and list or retry job status from within a workflow.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Related to Red Hat Ansible
Workflows logo
Workflows
Full version history
ReleaseDate
  • Various improvements and dependency updates.
This release improves the workflow templates for Red Hat Ansible by fixing the target configuration for Slack connections, ensuring that automated workflows can reliably send notifications to the correct Slack channels.
This release improves the stability and performance of the Red Hat Ansible app.
This release improves the stability of the Red Hat Ansible app.
This maintenance release is bundled with some minor quality of life improvements.
Improved app stability and performance through updated dependencies
  • Updated dependencies
  • Memorize the event stream setting between creating connections
  • add support for Red Hat event streams
2.0.2
Patch Changes
2.0.1
Patch Changes
  • Improved visual fidelity of connection management in modals
2.0.0
Major changes
  • Migrated to owner based access control (ACL)
2.0.0
Major changes
1.1.1
Patch Changes
1.1.0
Minor Changes
  • App is headless again. To control your connections, please use the Settings app.
Patch Changes
  • Add grouping of input fields in workflow widget.
1.1.0
Minor Changes
Patch Changes
1.0.1
Patch Changes
  • Change: "for Workflows" was removed from the app title
  • Chore: Increase URL limit to 255 characters
  • Fix: Launch job template did not wait until the job finished
1.0.0
This marks the first initial release of Red Hat Ansible for Workflows.
1.0.0
0.3.2
Patch Changes
  • Fix: eventData is now more resilient to different input types
  • Fix: Ensure that there is a default widget state to avoid data validation issues
0.3.1
Patch Changes
0.3.0
  • Breaking: connections have been changed from an ordered list to an unordered list. This was done in preparation for better ACL support. However, inserting connections via API or Monaco using insertAfter will no longer be possible.
0.3.1
Patch Changes
0.3.0
0.3.0
0.2.4
Patch Changes
0.2.3
Patch Changes
  • Fix typo in display name of settings schema
0.2.2
Patch Changes
  • Update app icon
  • Ensure proper handling of trailing slashes in API
  • Add sample results for all actions
  • Fix a typo in description
0.2.1
Patch Changes
  • Update dependencies
0.2.0
Minor Changes
  • Improve support for multi-line extraVars in Launch job template action
Patch Changes
  • Update app description and value statement
0.2.3
Patch Changes
  • ce0a373: fix typo in display name of settings schema
0.2.2
Patch Changes
  • 0d98026: Update app icon
  • b5c1248: Ensure proper handling of trailing slashes in API
  • 918d4a1: Add sample results for all actions
  • 6797e83: Fixed a typo in description
0.2.1
Patch Changes
0.2.0
Minor Changes
  • 19cf5a6: Improve support for multi-line extraVars in Launch job template action
Patch Changes
  • 041e0b9: Update dependencies
  • 11f148e: Update app description and value statement
0.2.1
Patch Changes
0.2.0
Minor Changes
Patch Changes
0.1.4
Patch Changes
0.1.3
Patch Changes
0.1.2
Patch Changes
  • 8f38470: Update dependencies
0.1.1
Patch Changes
  • 6e7a75d: Force resubmission of API token before saving connection configuration.
0.1.0
Minor Changes
  • da91c19: Introduced new actions launch-job-template, list-job-status and relaunch-job
No release notes
Dynatrace Hub
All (947)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Dynatrace Assist logo
Dynatrace Assist
Smartscape logo
Smartscape
Compliance Assistant logo
Experience Vitals logo
Experience Vitals
Optimize UX with core vitals, frontend error tracking, and end-to-end visibility.
Error Inspector logo
Error Inspector
Users & Sessions logo
Users & Sessions
Replay how users experience your frontend. Analyze behavior and outcomes.
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
