Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Snowflake for WorkflowsSnowflake for Workflows
Access, query, and store Snowflake data to analyze further within Dynatrace.
App
Free trialDocumentation
Add one of the two available actions: Query and process snowflake data from within the workflow or execute a query and store the results in Grail.Add the SQL statement to execute queries on Snowflake. Use the form fields to set relevant parameters.
  • Product information
  • Release notes
Overview
Unlock new use cases by integrating Snowflake data with data stored in Grail.
Enterprises are using diverse tools to address their business needs, resulting in separate data silos. Dynatrace's goal to provide complete visibility and get contextual insights doesn't stop at the edge of Grail and, therefore, natively integrates with multiple Enterprise tools.
Snowflake for Workflows is a fast, flexible, and secure way to query and process Snowflake data within Dynatrace. It adds two new actions to Workflows, which allows you to execute SQL statements and process the result sent in the response. You can use the result set within the workflow, enrich already available data, or persist it in Dynatrace as a new Business event.
Use cases
Access relational data from Snowflake to ...
  • contextualize data: enrich data stored in Grail with additional context from Snowflake
  • utilize Davis Analyzers on Snowflake data: pull in data to perform complex analysis by leveraging Dynatrace's anomaly detection and forecasting capabilities
  • address Data Observability use cases based on metadata stored in Snowflake
  • or gather new business analytics insights by joining observability data with data natively stored in Snowflake. This means your data stays always fresh - natively stored in Snowflake.
Get started
  • Install the connector
  • Set up and authorize the connection to Snowflake
  • Either create a new workflow or add one of the Snowflake actions to an existing one
  • Utilize the data to perform look-ups, reuse the data in adjacent workflow steps, or store it in Grail
  • Run the workflow on demand, periodically, or even triggered by specific events
  • Use Notebooks or Dashboards to query Snowflake data stored as Business events
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Related to Snowflake for Workflows
Grail logo
Grail
Dynatrace's data lakehouse providing unified storage for any type of data.
Snowflake logo
Snowflake
Expand visibility to improve health and performance monitoring of your Snowflake.
Workflows logo
Workflows
Full version history
ReleaseDate
Minor Changes
  • Added a "Validate" button to the Snowflake connection settings form.
  • The QUERY_TAG is now added to all Snowflake query execution requests. This allows for better tracking and monitoring of queries executed through the Dynatrace Snowflake connector.
  • The execute-statement action now supports executing multiple statements at once in the query
Patch Changes
  • Reconfigured secrets resubmission requirements. Now the user needs to re-enter credential values only if URL-type fields are changed.
  • Updated dependencies
Minor Changes
  • Adding PAT as an authentication method for Snowflake
Patch Changes
  • Updating dependencies
Patch Changes
  • Replaced "moment" library usage with "date-fns"
  • Fixing the issue of fractions not being properly represented - they were incorrectly scaled to higher values.
1.1.0
Minor Changes
Streaming the Snowflake response per data record to avoid issues with memory when loading whole partitions.
Patch Changes
1.0.0
The first official version of the Snowflake Connector.
Features
  • Snowflake for Workflows supports two types of actions:
    • execute-statement that just executes the SQL statement on Snowflake and returns the first partition of data as the result so other workflow actions can use it
    • store-statement-result that executes SQL statement on Snowflake and ingests all data partitions into Grail as either BizEvents or lookup tables.
Minor Changes
  • Replaced allowed users feature by access control settings.
  • Migrating actions to stateful actions, allowing them to pass the 2-min execution limit.
  • Added support for overwriting event.type field of BizEvents
  • Introduce a new, streamlined connection management experience with a modernized interface. This update makes adding and editing connections directly within workflows easier and provides connection control and convenience in one place.
  • Added lookup tables as an option of Grail storage type
Patch Changes
  • Disabling validations on expressions in the lookup file path
  • Fixing the error with the missing permission to create Lookup Tables. Improved logging in case of an error.
  • Fixed race conditions in lookup table creation if the request failed early during streaming
  • Supporting different data types for lookup tables ingest
  • Major dependencies updates
  • Improving UI performance for Snowflake Connector's form
  • The private key passphrase will no longer be a required field in the connection form
  • Dependency updates
1.0.0-preview.7
Patch Changes
  • Re-release for the 1.0.0-preview.6 version that couldn't be published due to dependencies bug.
1.0.0-preview.6
Minor Changes
Patch Changes
1.0.0-preview.5
Minor Changes
1.0.0-preview.4
Minor Changes
1.0.0-preview.3
Minor Changes
  • Added support for overwriting the event.type field of BizEvents
Patch Changes
1.0.0-preview.2
Minor Changes
  • Removing the allowedUsers property from the connection settings.
Patch Changes
  • Bug fix: Avoiding the "Invalid input value. Undefined is not a UUID" Snowflake error.
1.0.0-preview.1
Patch Changes
1.0.0-preview.0
Major Changes
  • Releasing the Preview version of Snowflake for Workflows
Minor Changes
  • Added support for specifying binding parameters for the Snowflake statement
Dynatrace Hub
All (947)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Dynatrace Assist logo
Dynatrace Assist
Smartscape logo
Smartscape
Compliance Assistant logo
Experience Vitals logo
Experience Vitals
Optimize UX with core vitals, frontend error tracking, and end-to-end visibility.
Error Inspector logo
Error Inspector
Users & Sessions logo
Users & Sessions
Replay how users experience your frontend. Analyze behavior and outcomes.
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
