Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
AI ObservabilityAI Observability
AI Observability
AI Observability
App
Free trialDocumentation
Send data with ease through OpenTelemetry for large number of technologiesEnd-to-end observability and monitoring for your Agentic and LLM applicationsAgent topology and visualization - get visibility into agent execution, tool usage and misbehaviorPrompts stream showing all Agent and LLM interactions with model version, token count, and full prompt/response content.Trace-level debug view showing agentic span hierarchy, tool calls, prompt and response content, and agent topology for a single AI agent run.LLM-as-judge evaluation detail with score, pass/fail label, explanation, and gen_ai.evaluation.* attributes.Visualize the evaluation results with pass/fail verdicts, scores, and explanations across agent runs, filterable by model and  providerA distributed trace waterfall with the browser user-action span at the top, and LLM/agent child spans nested underneath showing the RUM-to-AI linkage
  • Product information
  • Release notes
Overview
Businesses are adopting Agentic AI, GenAI services and apps at scale — using LLMs for autonomous agents, RAG pipelines, semantic search, and complex multi-step orchestration across dozens of providers and frameworks. Managing the performance, cost, quality, and reliability of these workloads requires purpose-built observability that understands AI-specific signals.
Dynatrace AI Observability provides a unified view across every layer of your whole AI stack: model and provider calls, orchestration frameworks, vector databases, agent topology, and infrastructure to coding agents. It ingests gen_ai.* telemetry from any source — Dynatrace OneAgent (zero-code, automatic), OpenTelemetry (native OTLP) or OpenInference and surfaces it in a single, consistent experience without requiring you to change your instrumentation approach
Beyond traces and metrics, Dynatrace AI Observability includes agent topology mapping via Smartscape, showing how agents call each other and which models and tools they depend on in real time. It also supports production AI quality evaluation through dt-evals, enabling LLM-as-judge scoring of live responses so quality regressions are caught alongside performance and cost issues. Set SLOs and get alerts the moment latency, error rate, or cost budgets are breached
Use cases
Monitor agent and model health and performance
  • Track request counts, durations, error rates, and token costs across providers and agent tiers in real time.
  • Set SLOs and get alerts the moment latency, error rate, or cost budgets are breached — with automated remediation workflows to route to fallback models or scale inference capacity.
Visualize agent topology and dependencies
  • Map your full multi-agent system in Smartscape — which agents call each other, which models they use, and which tools and vector stores they depend on.
  • Detect cascading failures and understand the blast radius of a model or provider outage instantly.
End-to-end prompt tracing and debugging
  • Trace prompt flows from user request through agent handoffs, tool calls, and retrieval to final response for faster root cause analysis.
  • Capture full prompt and response content (opt-in) to debug complex pipelines with span-level precision.
Evaluate AI quality in production
  • Score live responses with LLM-as-judge evaluations via dt-evals — completeness, relevance, toxicity — attached to the same spans as latency and cost.
  • Alert on quality score regressions using workflow engine, SLOs and combine with cost and latency signals for confident rollback or rollforward decisions.
Build trust and reduce compliance risk
  • Track every input and output for a complete audit trail, queryable in real time and stored for future reference.
  • Monitor guardrail activations — PII, topic, and content filters — as metrics with full data lineage from prompt to response.
Stitch browser sessions to AI agent traces
  • Connect every user click to the full backend AI span tree via Dynatrace RUM — W3C traceparent headers make each LLM call a child of the browser user-action span.
  • Reconstruct complete multi-turn agent trajectories from first question to final answer using a single gen_ai.conversation.id seeded from the RUM session ID.
Get started
Setting up full stack observability for your GenAI applications is possible with OpenTelemetry, or auto-instrumentation libraries like OpenInference, with OpenTelemetry under the hood, which can seamlessly provide comprehensive end-to-end insights into your production environments.
To set up OpenInference with Dynatrace, see Dynatrace Documentation.
You can access all these capabilities through customizable, ready-made dashboards tailored to your needs.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
More resources
Deliver secure, safe, and trustworthy GenAI applications with Amazon Bedrock and Dynatrace
Amazon Bedrock, equipped with Dynatrace Davis® AI and LLM observability, gives you end-to-end insight into the Generative AI stack, from code-level visibility and performance metrics to GenAI-specific guardrails.
Read more
AI and LLM Observability Solution
Leverage best-in-class observability to improve the performance, explainability, and compliance of your Generative AI applications, LLMs, and agents.
Read more
AWS Partner Blog: Elevating LLM Observability with Amazon Bedrock and Dynatrace
Dynatrace is an all-in-one observability platform that automatically collects production insights, traces, logs, metrics, and real-time application data at scale.
Read more
Full version history
ReleaseDate
2.14.1
Bug Fixes
  • fix evaluations for Vertex AI when using API keys
  • adjust required app permissions
2.13.0
New Features
  • improved Explorer Detail page with new Logs and Metadata cards
  • minor improvements in the AI Vulnerabilities dashboard
Bug Fixes
  • improve wording, names and titles of AI Guardrail coverage dashboard
  • Overview charts - average duration computes average now
2.12.0
New Features
  • added AI Guardrail Coverage dashboard
  • several improvements on the Evals page
Bug Fixes
  • fix metric charting for nodes details on Agents Topology page
  • fix toolbar placement in Agents Topology
2.11.0
New Features
  • Add filtering support to the Evals page
  • Add Quality and Coverage chart tabs to Evals page
  • Improve date formatting on the Evals page
  • Persist timeframe across all pages
Bug Fixes
  • Fix prompt detail panel failing to open in certain edge cases
  • Fix edges rendering in the Agents topology page
  • Reduce overall cost for data fetching
2.9.0
New Features
  • add Evals metric card to Overview and update cards
  • collapse system prompt by default in prompt details
Bug Fixes
  • content and naming consistency — rename Evaluations to Evals
  • fix dashboard DQLs
2.5.2
Patch Changes
  • Fixed permission handling
Release 2.5.0
Minor Changes
  • New consolidated AI Observability dashboard leveraging new Smartscape queries
  • Fixed formatting issues for Prompt details
  • New Markdown support for Prompt details
2.4.0
Minor Changes
  • Add model details for explorer
  • Move charts from service health to explorer
  • Improved search and filtering for Agent Topology
Patch Changes
  • Add an Evaluations ready-made dashboard for eval results generated by the dt-evals CLI.
  • Add workflow template for sending Slack notifications when new critical or high-severity vulnerabilities are detected in AI workloads.
  • Fix DQL issues in ready-made dashboards when there is no data
  • Fix for single service node doesn't show up in Agent Topology in prompts sheet
2.2.19
Patch Changes
  • Fixed single service node doesn't show up in agent topology in prompts sheet
  • Fixed CSS problems
2.2.16
Patch Changes
  • Add OneAgent onboarding flow with guided steps to configure features and validate data
  • Update empty and error state in the agents topology
  • Improve JSON wrapped in Markdown formatting in prompts details
2.2.15
Patch Changes
  • Add Agent Topology in the prompts details sheet
  • Fix detection of LLM spans in Prompt Details
  • Add intent into AI Observability app
  • Agents tab minor improvements
  • Fix Prompt input/output parsing in the services details
  • Fix cost estimation fallback in AB model versioning dashboard
2.2.14
Patch Changes
  • Fix AI Agent timestamp selection
2.2.13
Patch Changes
  • Fix AI Agents page DQL
  • Fix corner case for the DQL in the Service Health Failure chart
2.2.12
Patch Changes
  • Fix Unicode rendering in the Prompt tab
  • Fix prompts details trace table scrolling
  • Fix double loading of the Prompt page
  • Fix filter stability when navigating between pages
2.2.11
Patch Changes
  • Show prompt details sheet when a prompt is selected from the prompts page
2.2.10
Patch Changes
  • Improved DQL performance in the Prompt page
  • Fix Prompts microguide
  • Fix a problem with applying policies for fieldsets
  • Fix start_time column rendering on the Prompt page
  • Fix empty state rendering issues in the Prompt page
  • Fix HTTP Error trend chart DQL
2.2.8
Patch Changes
  • Improve DQL performance for the Prompt page
2.2.7
Patch Changes
  • Fix DQL in dashboards to compute error responses
2.2.6
Patch Changes
  • Minor improvements and 3rd party dependency updates
2.2.5
Patch Changes
  • Fix legend colors for Error rate over time chart
  • Fix Invocation latency chart unit
  • Improved data queries to reduce unnecessary costs spikes for the app
2.2.2
Patch Changes
  • Fix single value charts aggregations
2.2.1
Patch Changes
  • Fix navigation into Distributed Tracing
2.2.0
Minor Changes
  • Open Traces in a modal
  • Move explorer and service health out of Preview
  • Add sampling option to dashboard queries
  • Improve permissions check on onboarding screen
2.2.16
Patch Changes
2.2.15
Patch Changes
2.2.14
Patch Changes
2.2.13
Patch Changes
2.2.12
Patch Changes
2.2.11
Patch Changes
2.2.10
Patch Changes
2.2.8
Patch Changes
2.2.7
Patch Changes
2.2.6
Patch Changes
2.2.5
Patch Changes
2.2.2
Patch Changes
2.2.1
Patch Changes
2.2.0
Minor Changes
2.2.15
Patch Changes
2.2.14
Patch Changes
2.2.13
Patch Changes
2.2.12
Patch Changes
2.2.11
Patch Changes
2.2.10
Patch Changes
2.2.8
Patch Changes
2.2.7
Patch Changes
2.2.6
Patch Changes
2.2.5
Patch Changes
2.2.2
Patch Changes
2.2.1
Patch Changes
2.2.0
Minor Changes
2.2.14
Patch Changes
2.2.13
Patch Changes
2.2.12
Patch Changes
2.2.11
Patch Changes
2.2.10
Patch Changes
2.2.8
Patch Changes
2.2.7
Patch Changes
2.2.6
Patch Changes
2.2.5
Patch Changes
2.2.2
Patch Changes
2.2.1
Patch Changes
2.2.0
Minor Changes
2.2.13
Patch Changes
2.2.12
Patch Changes
2.2.11
Patch Changes
2.2.10
Patch Changes
2.2.8
Patch Changes
2.2.7
Patch Changes
2.2.6
Patch Changes
2.2.5
Patch Changes
2.2.2
Patch Changes
2.2.1
Patch Changes
2.2.0
Minor Changes
2.2.12
Patch Changes
2.2.11
Patch Changes
2.2.10
Patch Changes
2.2.8
Patch Changes
2.2.7
Patch Changes
2.2.6
Patch Changes
2.2.5
Patch Changes
2.2.2
Patch Changes
2.2.1
Patch Changes
2.2.0
Minor Changes
2.2.11
Patch Changes
2.2.10
Patch Changes
2.2.8
Patch Changes
2.2.7
Patch Changes
2.2.6
Patch Changes
2.2.5
Patch Changes
2.2.2
Patch Changes
2.2.1
Patch Changes
2.2.0
Minor Changes
2.2.10
Patch Changes
2.2.8
Patch Changes
2.2.7
Patch Changes
2.2.6
Patch Changes
2.2.5
Patch Changes
2.2.2
Patch Changes
2.2.1
Patch Changes
2.2.0
Minor Changes
2.2.8
Patch Changes
  • Improve DQL performance for the Prompt page to address performance issues
2.2.7
Patch Changes
2.2.6
Patch Changes
2.2.5
Patch Changes
2.2.2
Patch Changes
2.2.1
Patch Changes
2.2.0
Minor Changes
2.2.7
Patch Changes
2.2.6
Patch Changes
2.2.5
Patch Changes
2.2.2
Patch Changes
2.2.1
Patch Changes
2.2.0
Minor Changes
2.2.6
Patch Changes
2.2.5
Patch Changes
2.2.2
Patch Changes
2.2.1
Patch Changes
2.2.0
Minor Changes
2.2.5
Patch Changes
2.2.2
Patch Changes
2.2.1
Patch Changes
2.2.0
Minor Changes
2.2.2
Patch Changes
2.2.1
Patch Changes
2.2.0
Minor Changes
2.2.1
Patch Changes
2.2.0
Patch Changes
2.2.0
Minor Changes
2.1.2
Patch Changes
  • Minor UI improvements
2.1.1
Patch Changes
  • Filters are preserved across pages
  • Improved DQLs to handle corner cases
  • Removed guardrail charts
2.1.0
Minor Changes
  • Introduce a helper guide for the Overview page
  • Introduce a helper guide for the Service Health page
Patch Changes
  • Adjust colors for the Error Rate chart
  • Add ticks for Single Value Charts
  • Fix intent into Dynatrace Distributed Tracing
2.1.1
Patch Changes
  • Removed unused guardrail charts
2.1.0
Minor Changes
Patch Changes
2.1.0
Minor Changes
Patch Changes
2.0.8
Patch Changes
  • Disable segments selection if the user doesn't have permissions
  • Improve integration with other Apps
  • Improve DQLs covering edge cases
2.0.7
Patch Changes
  • Fix the problem of missing Ready-made Dashboards
2.0.6
Patch Changes
  • Improve App performance
  • Improve support for OpenTelemetry
2.0.5
Patch Changes
  • Fixed onboarding URL handling and example values for OpenLLMetry
  • Fixed Overview page calculation inconsistencies
2.0.4
Patch Changes
  • Fixes an issue where the "Overall average cost per request" would be miscalculated when there are no requests.
2.0.3
Patch Changes
  • Fixed token generation error handling.
  • Fixed cost calculation on the overview section.
  • Fixed onboarding video rendering.
2.0.1
Major Changes
  • Observability for 20+ AI, Agent and LLM technologies
  • Overview of your multi-cloud and multi-ai workloads setup and visibility into performance, cost, errors, latency metrics.
  • Visibility into model providers, LLMs and Agent calls, prompts, metrics, guardrails and traces.
  • Intelligent alerting for AI workloads
  • Dedicated onboarding experience for OpenTelemetry and Cloud Monitoring
  • Ready-made dashboards for AWS, Azure, OpenAI, NVIDIA, Kong, Model versioning and A/B testing
2.0.7
Patch Changes
2.0.6
Patch Changes
2.0.4
Patch Changes
2.0.3
Patch Changes
2.0.1
Major Changes
2.0.3
Patch Changes
2.0.1
Major Changes
2.0.1
Major Changes
1.3.1
Patch Changes
  • Fix handling the case of no data available
1.3.0
Minor Changes
  • Ready-made dashboard for model versioning and A/B testing of prompts
  • Ready-made dashboards for AI service compliance and audit trails
  • Ready-made dashboard for Kong AI Gateway
1.1.2
Patch Changes
  • a50eb79: Align naming
1.1.0
Minor Changes
  • 3288a76: Ready-Made dashboard for Google Gemini and Vertex AI Studio
Dynatrace Hub
All (958)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
